dont know if anyone knows but suspension techniques now sells front and rear swaybars.thinking about getting them.ill keep everyone updated
Read on, Grasshopper. R.paulj said:So what is different about these bars, compared to stock? Why would you change?
paulj
Duh, you get the Type R badge, yo!paulj said:The 'how sway bars work' tells me HOW they work, but doesn't say anything about how these aftermarket ones differ from the ones the Honda has put on the Element. It's not like you are ADDING something that is not already there. I'm pretty sure these bars replace the stock ones. But why? Is there a difference in bar diameter and stiffness? A $200 difference in bushings? A different shape that matters?
paulj
We need Strut Tower Bars, not sway bars.
You just think you're all that and a bag of potato chips, don't ya? :grin: Yeah, that does look great. I plan on doing that when it is warmer out. I just need to get some blue paint to match my AEM intake.Empire said:Geez, just paint all the stock bars a racey color and tell everyone you paid a Mugen tech $3k to custom fab them for you.:grin:
http://img102.exs.cx/img102/9251/image2498976hw.jpg![]()
The sway bars in that picture are not the actual sway bars. The ones in that picture have end links with polyurethane bushings. I just called up Suspension Technique. The guy said the front sway bar doesn't come with any end links or polyurethane bushings at all. The rear sway bars come with two polyurethane bushings, two mounting brackets, instructions, and grease for bushings. That's it. They don't even make end links or end link bushings for the Elements.Compan-E Car said:http://www.nopionline.com/nopistore...keid=140&vmodelid=201&vcatyear=2003&vnopinum=460+1056&vTitle=HONDA Element 2003 i'm not good at posting links but i'll try
I can't speak to *these* bars specifically, but increased diameter/stiffness (and occasionally end-link adjustability) are pretty much the reasons that you upgrade; stiffer bar = less body roll (with the price of increased ride stiffness/harshness). The shape of the bars will be very similar, as they have to replace the oem pieces, and there's only so many ways you can bend a rod between end links. The bushings are usually more along the lines of polyeurathane rather than softer rubber- again, increasing the stiffness, but with with the penalty of a harsher ride and more noise (squeaking). Upgraded bushings are usually included when you upgrade the sways as the bar diameters are different- the oem bushings just won't fit an aftermarket bar (although the mounting brackets are usually re-used). I've replaced the oem sways on three different cars I've owned (two of them were *complete* suspension rebuilds- wheels, tires, sways, shocks, struts, strut bars, bushings, end links, etc) and the best lubricant I've ever found to stop the squeaking is Energy Suspension Bushing Lubricant (called Formula5 Pre-lube). Unbelievably tacky; if you use it, be sure to use gloves, or you're tools will be literally sticking to your hands- let's just say it was a "lesson learned" from previous installs. R.paulj said:Is there a difference in bar diameter and stiffness? A $200 difference in bushings? A different shape that matters?
paulj
And in previous posts, I don't think the E has a strut bar. It is a sway bar. A strut bar connects the top of the left and right strut to eachother.
Take a look at these pics. This shows a strut bar installed on a Civic. It attaches to the bolts on the actual strut top mounts.Bigtzelement said:![]()
Hey SRLNCLT!
What do you think that red bar mounted between the right and left upper strut towers is?
That is the stock strut tower bar installed in every single E ever made.
However Empire has painted his a nice red, two thumbs up for that Empire!
At this point I refer you back to my original post.
Make sure you take some side by side pictures to help demonstrate the differences if any.Compan-E Car said:Just ordered mine about 20 mins ago , hopefully it will be here by this weekend for the install . I'll let you all know how good it really is
Damn nice Empire, I got this pic in another thread and meant to ask you what type of high heat paint did you use for the bar and engine covers?Empire said:Geez, just paint all the stock bars a racey color and tell everyone you paid a Mugen tech $3k to custom fab them for you.:grin:
